Welcome to TeardropForum.com › Forums › Teardrop Builders’ Forum › Anyone using 12v lithium battery? › Reply To: Anyone using 12v lithium battery?
August 23, 2017 at 5:31 am
#1228
adam–interesting battery holder. i’m a little skeptical about hanging 60 lb. from the 3/8 plywood bulkhead. sure wish CLC had chosen 3/4″ instead!
commcoy–a 50 amp hr battery should be fine. the only significant draw other than the vent fan is my computer, for watching baseball games. it has a 65 watt charger, but probably doesn’t draw nearly that much except when charging the battery or spinning the DVD.
where have you seen one for $350?
