Reply To: Building the trailer without a galley
Welcome to TeardropForum.com Forums Teardrop Builders’ Forum Building the trailer without a galley Reply To: Building the trailer without a galley
#791
restonthewind
A less radical approach only makes the galley space accessible from the interior. I cut a hole in the bulkhead, and I don’t build the hatch, but the build is unchanged otherwise.
Since the bulkhead supports the flat, a large hole leaving so little wood at the bottom seems risky, but I could install a table leg near the center of the flat screwed to the flat and the floor. I could also cut too, smaller holes and skip the table leg.
This approach seems foolproof (assuming I can build the thing at all), but I prefer removing more of the bulkhead, and I prefer omitting the galley altogether to either of these options. With the unused wood, I could build tables or something.
I ordered a kit today but won’t begin construction until early June. If anyone has built or considered building the trailer with similar modifications, or if you foresee a problem with these modifications, please chime in.
  • This reply was modified 8 years, 10 months ago by restonthewind.
