Reply To: Sourcing a Trailer in Canada
Welcome to TeardropForum.com › Forums › Teardrop Builders’ Forum › Sourcing a Trailer in Canada › Reply To: Sourcing a Trailer in Canada
I believe the width of the bottom of the shell is 60″. the length, measured from corner to corner, is 76″. the front protrudes another 6″ in the center.
I’m sure you could find a source of aluminum channel and construct your own frame. you of course would need an axle and leaf springs from a 5X8 or 5X10 trailer. if you end up buying a used axle, I would replace the hub assemblies. northern tools sells hubs for various-sized axle spindles for a decent price. 15″ wheel/trailer tire combos including shipping can be had for around $80US. I replaced the 12″ wheel/tires that came with the trailer with 15’s.
before I found the northern tools trailer, I had planned on visiting all the boatyards in my area to see if I could find a used boat trailer that would accommodate the mounting dimensions that are specified in the manual. if I had gone that route I would have made sure that the used trailer would have accommodated 15″ wheels.
