Welcome to TeardropForum.com › Forums › Teardrop Builders’ Forum › Fixing your doors – warpage
- This topic has 10 replies, 3 voices, and was last updated 5 years, 6 months ago by
canadianhoser.
June 16, 2020 at 11:20 am #3073
canadianhoser
ParticipantWhen performing the leak test on my teardrop, I found that I had some water intrusion around the doors. My doors are slightly bowed out at the mid-point of each panel, so they do not engage with the weather stripping properly. Since the bowing is not at the intersection of the two panels, adjusting the tensioning strap does not resolve this.
How have others resolved this issue. I’ll post the pictures in a follow-up, since my original post that included the pictures seems to be in some sort of quarantine.
June 16, 2020 at 11:21 am #3074canadianhoser
June 16, 2020 at 11:23 am #3075canadianhoser
June 16, 2020 at 2:26 pm #3076CWStevens
ParticipantI believe the foam weatherstripping is supposed to be applied to the perimeter of the door, not the door-frame. Then, (where you currently have weatherstripping) the water travels around the door and down to the bottom like a gutter. Weatherstripping in the top and bottom gutters may be preventing your door from closing properly in the mid-section.
Chris
June 16, 2020 at 3:23 pm #3080canadianhoser
ParticipantI was not a fan of the weatherstripping provided in the kit, so I ordered and installed D-shaped weatherstripping which filled in the channel on the chassis itself, making for a much cleaner looking installation. Only one door has this issue, with the other one having a good seal and no leakage.
June 16, 2020 at 6:14 pm #3082canadianhoser
June 16, 2020 at 6:15 pm #3083canadianhoser
ParticipantOnly the door bows out. The level against the exterior of the trailer is flat against the surface.
June 17, 2020 at 11:00 am #3084wudboatVT
ParticipantDo you have a link to the D shaped weatherstripping you used? I like the look. I’m also not a huge fan of what they provide in the kit…that said, it certainly has lasted on my two CLC kayaks.
John
June 17, 2020 at 12:09 pm #3085canadianhoser
ParticipantLook on Amazon for Trim-Lok D-Shaped Rubber Seal. I tried using the original weatherstripping first, but it did not stick well, and in places would stick out from the door seam as well.
The rubber seal also worked well for sealing up my mushroom vents. I had leaks with them until I replaced the weather stripping with the rubber seal.
June 17, 2020 at 1:04 pm #3086wudboatVT
ParticipantHey thanks!
For the good of the forum here’s the link to what I think you’re using. I’ll definitely give it a try.
June 17, 2020 at 2:53 pm #3087canadianhoser
ParticipantI installed the .437 inch height; .375 inch width version of this trim and it fit the channel perfectly.
