Reply To: Joint between galley Flat and bulkhead failed when plywood delaminated.
Welcome to TeardropForum.com Forums Teardrop Builders’ Forum Joint between galley Flat and bulkhead failed when plywood delaminated. Reply To: Joint between galley Flat and bulkhead failed when plywood delaminated.
#1721
rlheestand
Prepared the galley  by sanding off the varnish with 150 grit sandpaper and removing shards of plywood veneer and old epoxy fillet.  In each case the epoxy had pulled the veneer off the plywood sheet.  I added a new fillet (slightly broader) and immediately added a 3 inch fiberglass tape between the galley flat and the bulkhead.  I am waiting for CLC to send a strip of 4 inch fiberglass tape which I will apply to the joint from within the cabin.
Joint sanded and prepared for tape
Prepared for tape
Preparation (detail)
Preparation closeup
Tape added
tape added
  • This reply was modified 8 years, 2 months ago by rlheestand.
