Reply To: Headliner
#1539
mpilone
@faithie999 I agree that the headliner kit is a little overpriced for what you get. As @apkley pointed out, the material scratches and nicks very easily and as you pointed out, it still requires a good bit of work to fit, trim, and round over all the edges. It does look nice when complete but not $300 worth of nice.
It is definitely thicker than the interlocking floor mat material and it has a nicer, suede like texture to it. I debated for a while on installing it and looked at using floor mats or carpet squares. I priced them out to about $120 for the same amount of material assuming you don’t want to piece together a bunch of small scraps. But after considering the time to make templates and cut all the odd curves and shapes I decided to go with the headliner and make more progress on the trailer.
It would be nice if CLC sold a $30 template set for the headliner and then let you pick your own material. Other than the CNC or printer time for CLC it would be pure profit and people could then pick the material that works best for them. While I do think the headliner is over priced, if you value your time at all I think it is the fastest way to get the job done. When this liner gets scratched and dinged, as it inevitably will, I’m hoping to use the pieces as the templates for the next set I make out of cheaper materials which offsets the cost a bit in the long run.
-mike
