Welcome to TeardropForum.com › Forums › Teardrop Builders’ Forum › Building the hopitat › Reply To: Building the hopitat
Just got back from a 3500 mile road trip. Absolutely nothing came loose, broke or failed. I did have a few modifications I need to make.
There is a gap in my insulation at the bulkhead, which I need to fill to reduce condensation in that area. I will also make some inserts for the door/window to reduce condensation there when conditions require. We just stuck pillows between the window and strap which did great to reduce condensation and a bit more insulation when it was 26 deg. We had no heat but used sleeping bags then, and that did fine. Wife won’t let me run the fan because she just hates fans, so condensation was always present but not extreme or too bothersome. Later I left my door unlatched which let a bit more air in and really made a difference. All in all we were very cozy from 26 in Rogue River to the 70s at the San Diego beaches.
I am also going to add some yellow side running lights to make the trailer more visible in miserable road conditions. And we did hit some of those conditions. Hundreds of miles of snow and then slush on the freeway. The trailer pulled like a champ behind our subaru outback.
I had mounted the front mushroom vents on #2 vice #1 panels, to make sure they didn’t get blocked by the wife’s mountain of pillows, and I thought they looked better there. Well that put them right in the slush zone! In the end there was only a few ounces of water that came through doors and vents, I assume from snow buildup mostly. I was OK with that. When I washed the Hopitat today, I really soaked it and nothing leaked, with the exception of a tablespoon or so in the back corner of the galley. Really happy about that and will not change anything.
