Reply To: sanding/dressing the galley hatch and door openings stevie Reply To: sanding/dressing the galley hatch and door openings2017-06-13T16:57:40-04:00 Welcome to TeardropForum.com › Forums › Teardrop Builders’ Forum › sanding/dressing the galley hatch and door openings › Reply To: sanding/dressing the galley hatch and door openings June 13, 2017 at 4:57 pm #913 stevieParticipant Unless your saw kerf is awfully thin, I believe you’ll find the gap just fine. I used the Dremel saw and a Bosch sabre/jig saw for doors and hatch. Some builders stated they had difficulty with the doors rubbing against the eyebrows, but I didn’t.
