March 11, 2017 at 5:56 pm
#649
Applied a last coat of epoxy over the whole camper. Working on interior epoxy as well, doing finish detail sanding. Amazing how many “nits” there are when you start running your hand over everything. Also de-dusting with an alcohol rag, which also finds nits. Did an exterior finish sanding session and got about 1/2 done with the initial 220 grit sanding. I’ll hit it with 320 and then wet sand with 400, then varnish.
