Hey Bob,
Looking at your pictures I note that your fenders look like they are not in the lowest bolt hole position. It is easy, but you will find that, if so, you will need to lower them to avoid interference with the teardrop which is slightly wider than the Trailex frame. You do NOT need to remove the tires to do this.
Eric
